주요 콘텐츠로 건너뛰기
Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement
필요한 것
  1. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  2. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  4. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  6. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
Buenas noches tu vendes la tapa trasera del Razer Blade 15 Advanced Model (Early 2020) RZ09-033
Germán Hernández - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 40
전체 시간: 1,251
