주요 콘텐츠로 건너뛰기
Razer Blade 15 Advanced Model (Early 2020) SSD Replacement
필요한 것
  1. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: 2 단계, 이미지 2개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: 2 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: 4 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 6 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 6 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 7 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 7 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: 7 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: 9 단계, 이미지 2개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the SSD.
    • A sticker may cover the SSD screw. Pierce through it with your screwdriver or use tweezers to remove it.
    • With the screw removed, the SSD will pop up at a shallow angle.
  10. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: 10 단계, 이미지 2개 중 1개 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: 10 단계, 이미지 2개 중 2개
    • Pull the SSD straight out of its socket to remove it.
    • During reassembly, insert the SSD into its socket at a slight downward angle.
결론
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,369 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,611개를 작성함
1가이드 댓글
Why need to disconnect the battery to remove SSD.
M I - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 74
전체 시간: 1,764
