주요 콘텐츠로 건너뛰기
Razer Blade 15" (2018) Back Cover Replacement
필요한 것
  1. Razer Blade 15" (2018) Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 1개 중 1개
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  2. Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 3 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  4. Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 4 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
95,536 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,776개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 56
전체 시간: 965
