소개
A guide to remove and replace the battery for the Razer Blade RZ09-0102. You may want to replace your battery if the battery cannot hold a charge or drains after an unreasonably short time. The battery needs to be removed if working on other components as well.
필요한 것
Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
Remove the back cover.
Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
