주요 콘텐츠로 건너뛰기
Razer Blade RZ09-0130 2015 Fan Replacement
필요한 것
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: 2 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Fan Replacement: 2 단계, 이미지 2/2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: 3 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: 4 단계, 이미지 1/1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: 5 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Fan Replacement: 5 단계, 이미지 2/2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: 6 단계, 이미지 1/3 Razer Blade RZ09-0130 2015 Fan Replacement: 6 단계, 이미지 2/3 Razer Blade RZ09-0130 2015 Fan Replacement: 6 단계, 이미지 3/3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: 7 단계, 이미지 1/1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: 8 단계, 이미지 1/1
    • Repeat the preceding steps to remove the second fan.
결론
Tyler Clayton
회원 가입일: 01/22/20
183 평판
안내서 1개 작성함
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 회원
CPSU-WHITE-W20S18G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 599
