주요 콘텐츠로 건너뛰기
Razer Blade RZ09-0130 2015 Speaker Replacement
필요한 것
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: 2 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: 4 단계, 이미지 1/2 Razer Blade RZ09-0130 2015 Speaker Replacement: 4 단계, 이미지 2/2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: 5 단계, 이미지 1/1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: 6 단계, 이미지 1/1
    • Repeat the preceding steps to remove the second speaker.
결론
Carson Kellerman
회원 가입일: 01/29/20
495 평판
안내서 4개 작성하였습니다
Cal Poly, Team S18-G1, White Winter 2020 Cal Poly, Team S18-G1, White Winter 2020 회원
CPSU-WHITE-W20S18G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 332
