주요 콘텐츠로 건너뛰기
Razer Blade Stealth 2016 Fan Replacement
필요한 것
  1. Razer Blade Stealth 2016  Fan Replacement, Battery: 1 단계, 이미지 1/3 Razer Blade Stealth 2016  Fan Replacement, Battery: 1 단계, 이미지 2/3 Razer Blade Stealth 2016  Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016  Fan Replacement: 2 단계, 이미지 1/2 Razer Blade Stealth 2016  Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016  Fan Replacement: 3 단계, 이미지 1/1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016  Fan Replacement, Fans: 4 단계, 이미지 1/2 Razer Blade Stealth 2016  Fan Replacement, Fans: 4 단계, 이미지 2/2
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
  5. Razer Blade Stealth 2016  Fan Replacement: 5 단계, 이미지 1/1
    • Carefully lift and remove the left fan.
  6. Razer Blade Stealth 2016  Fan Replacement: 6 단계, 이미지 1/3 Razer Blade Stealth 2016  Fan Replacement: 6 단계, 이미지 2/3 Razer Blade Stealth 2016  Fan Replacement: 6 단계, 이미지 3/3
    • Repeat steps five and six to remove the silver, right fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katie Murphy
회원 가입일: 10/10/19
139 평판
안내서 1개 작성함
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I’m trying to figure out how to attach the ribbons to the motherboard.
Richard Howard - 답글
Are the two fans the same?
Mohd Azli Mahmud - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 26
전체 시간: 1,723
