주요 콘텐츠로 건너뛰기
Razer Blade Stealth 2016 Hard Drive Replacement
필요한 것
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: 2 단계, 이미지 1/1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: 3 단계, 이미지 1/1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: 4 단계, 이미지 1/1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: 5 단계, 이미지 1/2 Razer Blade Stealth 2016 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: 6 단계, 이미지 1/2 Razer Blade Stealth 2016 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Carefully slide the hard drive out from its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lindsay Grant
회원 가입일: 10/10/19
403 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 32
전체 시간: 2,676
