주요 콘텐츠로 건너뛰기
Razer Blade Stealth 2016 Motherboard Replacement
필요한 것
  1. Razer Blade Stealth 2016 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Razer Blade Stealth 2016 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Razer Blade Stealth 2016 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Razer Blade Stealth 2016 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Razer Blade Stealth 2016 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Razer Blade Stealth 2016 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
2가이드 댓글
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Matias Urani - 답글
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
Sarah Westberg -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 1,050
