소개
The speakers in your Razer Blade Stealth 2016 (Model # RZ09-01682E20) are the only source of sound in your laptop besides Bluetooth and the headphone jack. So if your speakers fail, you might want to replace them. This guide will show you how to remove and replace the speakers in your Razer Blade Stealth 2016.
필요한 것
Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
Remove two 3.4 mm screws from each speaker using a T4 Torx screwdriver.
Remove the speakers from the laptop.
