주요 콘텐츠로 건너뛰기
Razer DeathAdder Chroma Scroll Wheel Replacement
필요한 것
  1. Razer DeathAdder Chroma Scroll Wheel Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Scroll Wheel Replacement: 2 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 2 단계, 이미지 2/2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Scroll Wheel Replacement: 3 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Scroll Wheel Replacement: 4 단계, 이미지 1/1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Scroll Wheel Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 1/3 Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 2/3 Razer DeathAdder Chroma Scroll Wheel Replacement: 6 단계, 이미지 3/3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Scroll Wheel Replacement: 7 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: 8 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement, Motherboard: 8 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Scroll Wheel Replacement: 9 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Scroll Wheel Replacement: 10 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 10 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Scroll Wheel Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Scroll Wheel Replacement: 12 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 12 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Scroll Wheel Replacement: 13 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement: 13 단계, 이미지 2/2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: 14 단계, 이미지 1/2 Razer DeathAdder Chroma Scroll Wheel Replacement, Scroll Wheel: 14 단계, 이미지 2/2
    • Remove the scroll wheel from the socket by pulling to the right.
    • Pulling too hard could damage the scroll wheel connector.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Corrie Tung
회원 가입일: 03/24/17
702 평판
안내서 2개 작성하였습니다
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 81
전체 시간: 18,923
