주요 콘텐츠로 건너뛰기
Razer DeathAdder Chroma USB Cable Replacement
필요한 것
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma USB Cable Replacement: 2 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 2 단계, 이미지 2/2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma USB Cable Replacement: 3 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma USB Cable Replacement: 4 단계, 이미지 1/1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma USB Cable Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 1/3 Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 2/3 Razer DeathAdder Chroma USB Cable Replacement: 6 단계, 이미지 3/3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma USB Cable Replacement: 7 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: 8 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: 8 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
    There are 2 tiny locking pins at the back you may need to spudge the connector casing a bit on each side to release these , I did.
    John bayley - 답글
  9. Razer DeathAdder Chroma USB Cable Replacement: 9 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma USB Cable Replacement: 10 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 10 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma USB Cable Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
    Does anyone know what the circuitry this screw holds in place does, I completely missed this tiny screw and accidently snapped the 2 soldered components off named D2 & D3… But the mouse still works fine ?? however i do not use razer synapse anymore so i dont know if its 100% working
    woolstarr - 답글
    Never mind it just came to my attention there is a set of LEDs in the mouse wheel which is what that tiny board is, soo …. RIP Mouse Wheel LEDs
    woolstarr - 답글
  12. Razer DeathAdder Chroma USB Cable Replacement: 12 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 12 단계, 이미지 2/2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma USB Cable Replacement: 13 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 13 단계, 이미지 2/2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: 14 단계, 이미지 1/1
    • Locate the USB cable.
  15. Razer DeathAdder Chroma USB Cable Replacement: 15 단계, 이미지 1/2 Razer DeathAdder Chroma USB Cable Replacement: 15 단계, 이미지 2/2
    • Remove the USB cable by pulling it up and out.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Henry Shi
회원 가입일: 03/26/17
221 평판
안내서 1개 작성함
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G2
3 회원들
안내서 6개 작성하였습니다
댓글 5개
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - 답글
Thanks for the advice
João Costa Santos -
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - 답글
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - 답글
where can i get the cable from?
Mourya Singham - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 36
전체 시간: 14,358
