소개
The Razer DeathAdder Chroma may experience critical issues related to the device not being registered by the computer via a fault in the USB cable.
필요한 것
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
There are 2 tiny locking pins at the back you may need to spudge the connector casing a bit on each side to release these , I did.
Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - 답글
Thanks for the advice
Is there a reliable website where I can get a replacement cable with low delivery time?
where can i get the cable from?
