이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Use your fingers to identify the location of the screw under the bottom label.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Disconnect the ribbon connector between the motherboard and the optical sensor.
Remove the motherboard by grasping the sides and gently pulling upward.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - 답글
Thanks for the advice
Is there a reliable website where I can get a replacement cable with low delivery time?
where can i get the cable from?
