주요 콘텐츠로 건너뛰기
Razer Huntsman Tournament Edition Mainboard Replacement
필요한 것
  1. Razer Huntsman Tournament Edition Mainboard Replacement, Keycaps: 1 단계, 이미지 1개 중 1개
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Mainboard Replacement: 2 단계, 이미지 2개 중 1개 Razer Huntsman Tournament Edition Mainboard Replacement: 2 단계, 이미지 2개 중 2개
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Mainboard Replacement: 3 단계, 이미지 3개 중 1개 Razer Huntsman Tournament Edition Mainboard Replacement: 3 단계, 이미지 3개 중 2개 Razer Huntsman Tournament Edition Mainboard Replacement: 3 단계, 이미지 3개 중 3개
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Mainboard Replacement, Chassis: 4 단계, 이미지 1개 중 1개
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Mainboard Replacement: 5 단계, 이미지 3개 중 1개 Razer Huntsman Tournament Edition Mainboard Replacement: 5 단계, 이미지 3개 중 2개 Razer Huntsman Tournament Edition Mainboard Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
  6. Razer Huntsman Tournament Edition Mainboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Mainboard Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Mainboard Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Mainboard Replacement, Key Switch: 9 단계, 이미지 2개 중 1개 Razer Huntsman Tournament Edition Mainboard Replacement, Key Switch: 9 단계, 이미지 2개 중 2개
    • Gently push the key switch off of the mainboard with your thumb.
  10. Razer Huntsman Tournament Edition Mainboard Replacement, Mainboard: 10 단계, 이미지 2개 중 1개 Razer Huntsman Tournament Edition Mainboard Replacement, Mainboard: 10 단계, 이미지 2개 중 2개
    • Remove all of the switches.
  11. Razer Huntsman Tournament Edition Mainboard Replacement: 11 단계, 이미지 1개 중 1개
    • Replace the motherboard.
    • Do this in a gentle manner
결론
작성자
2다른 기여자 명과 함께
Joseph O'Dowd
회원 가입일: 10/25/22
401 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G3
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 65
전체 시간: 3,721
