주요 콘텐츠로 건너뛰기
Razer Huntsman Tournament Edition Port Replacement
필요한 것
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: 1 단계, 이미지 1개 중 1개
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: 2 단계, 이미지 2개 중 1개 Razer Huntsman Tournament Edition Port Replacement: 2 단계, 이미지 2개 중 2개
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: 3 단계, 이미지 3개 중 1개 Razer Huntsman Tournament Edition Port Replacement: 3 단계, 이미지 3개 중 2개 Razer Huntsman Tournament Edition Port Replacement: 3 단계, 이미지 3개 중 3개
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: 4 단계, 이미지 1개 중 1개
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: 5 단계, 이미지 3개 중 1개 Razer Huntsman Tournament Edition Port Replacement: 5 단계, 이미지 3개 중 2개 Razer Huntsman Tournament Edition Port Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
  6. Razer Huntsman Tournament Edition Port Replacement: 6 단계, 이미지 1개 중 1개
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: 9 단계, 이미지 2개 중 1개 Razer Huntsman Tournament Edition Port Replacement, Port: 9 단계, 이미지 2개 중 2개
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: 10 단계, 이미지 1개 중 1개
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the USB board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph O'Dowd
회원 가입일: 10/25/22
401 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G3
5 회원들
안내서 7개를 작성함
1가이드 댓글
how do i get a new port and where
Guardian Suit - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 27
전체 시간: 590
