주요 콘텐츠로 건너뛰기
Razer Huntsman Tournament Edition Rubber Feet Replacement
필요한 것
  1. Razer Huntsman Tournament Edition Rubber Feet Replacement, Rubber Feet: 1 단계, 이미지 1/1
    • Turn the keyboard upside down such that it it laying on its face.
    • The keys on the keyboard are facing away from you.
  2. Razer Huntsman Tournament Edition Rubber Feet Replacement: 2 단계, 이미지 1/3 Razer Huntsman Tournament Edition Rubber Feet Replacement: 2 단계, 이미지 2/3 Razer Huntsman Tournament Edition Rubber Feet Replacement: 2 단계, 이미지 3/3
    • Use the iFixit Opening Tool or a flat head screwdriver to pry off the rubber feet.
    • Peel the papers off the new rubber feet gently.
    • Before placing the new rubber feet use alcohol to wipe the surrounding area where the new rubber feet are going to be placed.
  3. Razer Huntsman Tournament Edition Rubber Feet Replacement: 4 단계, 이미지 1/1
    • Put in replacement rubber feet where the original rubber feet were at.
    • Wait a few minutes for the adhesive to set.
결론
Your keyboard should have replaced rubber feet (or foot if you replaced one).
Ben Altman
회원 가입일: 10/25/22
229 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 10
전체 시간: 214
