소개
Use this guide to replace the trigger on your Razer Kishi.
Both controller sides of the Razer Kishi are almost identical in construction. The process of replacing the triggers are almost identical on both sides, so in this guide we only show the right side.
필요한 것
For the right side, remove the five Y0 screws securing the right side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
Slide the opening pick along the right edge to loosen the plastic clips.
Slide the opening pick along the top edge to loosen the remaining plastic clips.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Pull the cable out of the socket.
Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
Remove the breakout board by lifting it straight up, away from the controller.
Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 5개
Thankyou so much my trigger slipped out and this was extremely helpfull ??
Hola donde puedo conseguir las partes de repuesto?
THANK YOU VERY MUCH! My R2 trigger got removed and its hinge is cracked, just super glued it but I have no idea how to fix it. Thanks to this guide, I returned it easy with no damages. (Took 15 minutes on a newbie like me)
Excelente.... ¡ Y donde consigo el repuesto?
During reassembly, when snapping the outer shell together test the R2 button. If it won't move it's likely because the tab on the end got pushed to the outside of the case. Pop it back open and push the R2 button in as you snap it back together in that area.
