주요 콘텐츠로 건너뛰기
Razer Kraken 7.1 Chroma Microphone Replacement
필요한 것
  1. Razer Kraken 7.1 Chroma Microphone Replacement, Ear Cushion: 1 단계, 이미지 1/1
    • Grab the ear cushion between your thumb and forefinger.
  2. Razer Kraken 7.1 Chroma Microphone Replacement: 2 단계, 이미지 1/1
    • Pull the ear cushion away from the speaker by sliding down to release the cushion from the plastic covering.
  3. Razer Kraken 7.1 Chroma Microphone Replacement: 3 단계, 이미지 1/1
    • Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed.
  4. Razer Kraken 7.1 Chroma Microphone Replacement, Speaker: 4 단계, 이미지 1/3 Razer Kraken 7.1 Chroma Microphone Replacement, Speaker: 4 단계, 이미지 2/3 Razer Kraken 7.1 Chroma Microphone Replacement, Speaker: 4 단계, 이미지 3/3
    • Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
    • Insert the plastic spudger in between the speaker and the headset directly in line with one of the exposed screws of the headset casing, since that is where the four clamps that hold the speaker to the headset are located. These clamps are not visible until after speaker removal.
    • Make sure to insert the spudger in between the foam buffer-ring and the headset casing instead of in between the speaker and the foam buffer-ring.
    • Reassembly may be tricky, there is one clamp smaller than others, so you have to align it correctly.
  5. Razer Kraken 7.1 Chroma Microphone Replacement: 5 단계, 이미지 1/1
    • Cut both wires connecting the speaker to the headset by using a wire stripper or pair of scissors.
    • Cut as close as possible to the connections on the speaker circuit board.
  6. Razer Kraken 7.1 Chroma Microphone Replacement, Speaker Casing: 6 단계, 이미지 1/2 Razer Kraken 7.1 Chroma Microphone Replacement, Speaker Casing: 6 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove all four 9mm screws.
    • Rotate the screwdriver counterclockwise when removing each screw.
  7. Razer Kraken 7.1 Chroma Microphone Replacement: 7 단계, 이미지 1/3 Razer Kraken 7.1 Chroma Microphone Replacement: 7 단계, 이미지 2/3 Razer Kraken 7.1 Chroma Microphone Replacement: 7 단계, 이미지 3/3
    • Pull the casing upwards to remove it from the headset.
    • If you are removing the casing on the side of the microphone, slide the casing towards you along the length of the microphone until the casing is completely removed.
  8. Razer Kraken 7.1 Chroma Microphone Replacement, Microphone: 8 단계, 이미지 1/2 Razer Kraken 7.1 Chroma Microphone Replacement, Microphone: 8 단계, 이미지 2/2
    • Slide the speaker case laterally along the length of the microphone until the casing is completely detached from the headset.
  9. Razer Kraken 7.1 Chroma Microphone Replacement: 9 단계, 이미지 1/3 Razer Kraken 7.1 Chroma Microphone Replacement: 9 단계, 이미지 2/3 Razer Kraken 7.1 Chroma Microphone Replacement: 9 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the 9 mm screws circled in red.
    • Rotate the screwdriver in a counterclockwise direction to remove each screw.
    • There is a total of four 9mm screws that must be unscrewed.
    • While unscrewing the spinning-wheel apparatus, remove only one wheel to free the microphone cable.
    • When removing the two-screw anchoring piece, slide it off of the broken microphone and make sure to slide the piece back on to the new microphone before soldering.
  10. Razer Kraken 7.1 Chroma Microphone Replacement: 10 단계, 이미지 1/1
    • Pull the microphone out towards you until it is no longer confined within the headset.
  11. Razer Kraken 7.1 Chroma Microphone Replacement: 11 단계, 이미지 1/2 Razer Kraken 7.1 Chroma Microphone Replacement: 11 단계, 이미지 2/2
    • Pull the plastic attachment with the screw-hole away from the rubber microphone casing to expose the microphone wire.
    • Cut the microphone wire as close to the rubber microphone casing as possible to give enough wire to work with for re-soldering the new microphone to the headset.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Karissa Sealey
회원 가입일: 03/24/17
995 평판
안내서 4개 작성하였습니다
Baylor, Team S5-G3, Williams Spring 2017 Baylor, Team S5-G3, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G3
3 회원들
안내서 8개 작성하였습니다
댓글 9개
Hey, Please answer I need your help. Where can I buy only the microphone?
BeN KazaV - 답글
I’ve come so far as the last picture but is it possible to post a picture of the cirquit board? as to where to solder the microphone to ( wich points ) since all my wires came unudone i cant tell i tried looking online for a schematic no luck.
Yoshiharu Sakurai - 답글
is it possible to post a picture of the cirquit board with locations where components need to be soldered on to? all my connections became undone so im trying to figure out where each of them is attached i cannot find any schematic online.
Nice guide. But not very useful, since I can’t find any place to buy a new microphone. Has anyone found a place to buy a replacement?
Michael Engesgaard - 답글
I was able to do this repair (on the non-Chroma version) without using a spudger or cutting the speaker wires by just poking through the black paper around the speaker to get access to the screws, skipping steps 4 and 5.
gary600 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 53
전체 시간: 17,163
