주요 콘텐츠로 건너뛰기
Razer Kraken Ultimate Speaker Replacement
필요한 것
  1. Razer Kraken Ultimate Speaker Replacement, Ear Pads: 1 단계, 이미지 1/3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: 1 단계, 이미지 2/3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: 1 단계, 이미지 3/3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Speaker Replacement: 2 단계, 이미지 1/2 Razer Kraken Ultimate Speaker Replacement: 2 단계, 이미지 2/2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Speaker Replacement: 3 단계, 이미지 1/2 Razer Kraken Ultimate Speaker Replacement: 3 단계, 이미지 2/2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Razer Kraken Ultimate Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Razer Kraken Ultimate Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Speaker Replacement: 5 단계, 이미지 1/2 Razer Kraken Ultimate Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Speaker Replacement: 6 단계, 이미지 1/2 Razer Kraken Ultimate Speaker Replacement: 6 단계, 이미지 2/2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
결론
Alex Broggi
회원 가입일: 10/24/22
342 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-4, Petersen Fall 2022 UMass Dartmouth, Team 1-4, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G4
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 434
