소개
The volume wheel of the Razer Kraken Ultimate can get stuck or otherwise broken, you can replace it or remove it to clean.
The volume wheel is stuck if it is either difficult or impossible to turn. It also should be replaced if headphones are connected to a computer and the volume wheel does not do anything.
필요한 것
The volume wheel is located on the daughterboard.
Remove the single 6.0 mm Philips #00 screw.
거의 끝나갑니다!
결론
