주요 콘텐츠로 건너뛰기
Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix
필요한 것
  1. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 1 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 1 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 1 단계, 이미지 3/3
    • Remove the single screw using a Phillips #000 screwdriver.
    • Peel back the sticker on the mouse to reveal the two screws behind it.
    • Remove the two screws using a Phillips #000 screwdriver.
  2. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 2 단계, 이미지 1/2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to pry open your mouse.
    • Detach the ribbon cable by squeezing the two grey latches and pulling it out gently.
  3. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 3 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 3 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 3 단계, 이미지 3/3
    • Use your hands to lift the battery out of the mouse.
    • The battery's wire is still attached to the mouse, so use caution.
    • Use your fingers to detach the cable from the mouse.
  4. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 4 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 4 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 4 단계, 이미지 3/3
    • Unscrew the five 1.4 mm screws using the Phillips #000 screwdriver.
    • Detach the wire that is connected to the scroll wheel.
    • Be gentle when pulling on the wire, or it could tear.
  5. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 5 단계, 이미지 1/2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 5 단계, 이미지 2/2
    • Dip a cotton swab in hydrogen peroxide.
    • Clean the scroll wheel by dabbing the cotton swab around it.
    • Do not put too much hydrogen peroxide on the cotton swab or else the scroll wheel could get damaged.
  6. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 6 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 6 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 6 단계, 이미지 3/3
    • Reinsert the wire back into its socket.
    • Insert and tighten the five 1.4 mm screws with the Phillips #000 screwdriver.
  7. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 7 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 7 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 7 단계, 이미지 3/3
    • Connect the battery wire back into the latch.
    • Put the battery back into the battery holder.
  8. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 8 단계, 이미지 1/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 8 단계, 이미지 2/3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 8 단계, 이미지 3/3
    • Connect the wire back into the latch.
    • Screw back the three screws using a Phillips #000 screwdriver.
    • Replace the sticker that was covering the top two screws.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Kevin Velez
회원 가입일: 04/04/22
238 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-99, Briggs Spring 2022 CSU Los Angeles, Team 4-99, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G99
1 회원
안내서 1개 작성하였습니다
댓글 2개
Listen screw driver is incorrect. Poor disassembly instructions that can easily lead to further irreparable damage to the mouse. Incredibly disappointing
Benjamin Parker - 답글
Cry me a river! If the screwdriver is incorrect i.e., doesn't fit into the screw correctly, don't attempt to make it work but instead try a different sized screwdriver. Wow! What a concept! Quit with the dramatics and just be glad that Kevin took the time to make this guide.
Michael Kolman -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 36
30일 전: 219
전체 시간: 11,344
