주요 콘텐츠로 건너뛰기
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement, Ear Cushions: 1 단계, 이미지 1/1
    • The ear cushions are removed from the device by slightly different methods.
    • To remove the left ear cushion (the side with the boom), rotate the cushion counter clockwise as far as it can turn, then pull the ear cushion straight out from the device.
    • To remove the right ear cushion, rotate it clockwise as far as it can turn, then pull the ear cushion straight out from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement: 2 단계, 이미지 1/1
    • In order to remove the cushion from the plastic backing, slide the leather free of the plastic edge, working around the entire cushion until it separates.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Schober
회원 가입일: 02/24/14
640 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,690
