주요 콘텐츠로 건너뛰기
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement
필요한 것
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • If the damaged speaker is in the left ear piece, remove the left ear cushion by rotating it counter clockwise (ear piece with microphone boom). For the right speaker, the right ear cushion must be turned clockwise to remove.
    • For additional information on removing the ear cushions, reference the Ear Cushions replacement guide.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 2 단계, 이미지 1/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 2 단계, 이미지 2/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 2 단계, 이미지 3/3
    • To get to the speaker you need to remove the six 5mm screws from the inner housing plate.
    • After doing this you can pull the housing apart exposing the speaker.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 3 단계, 이미지 1/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 3 단계, 이미지 2/3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 3 단계, 이미지 3/3
    • Use a knife to cut the glue around the speaker that is holding it to the assembly.
    • Once the glue is cut, pry the speaker out. Cut the wires at the base of the speaker and then replace them.
    • A solder gun will be needed to solder the wires onto the new speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Schober
회원 가입일: 02/24/14
640 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개 작성하였습니다
댓글 3개
Great guide!!
What speaker do i need to buy, where can i buy it ?
thank you!
Tom Van Aken - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 4,294
