소개
This guide will detail how to disassemble the maelstrom audio control device and repair a damaged wire connection.
필요한 것
To get to the maelstrom wiring you must first pull off the plastic cover.
To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
Then remove the four 8.5mm screws on the back plate of the maelstrom.
Once the four screws are removed, the top cover can be lifted off.
There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
Remove the three 2mm screws from the circuit board to separate it from the back plate.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 4개
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
can you provide the connection map for the cables that go prom remote root to headphones?
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
