주요 콘텐츠로 건너뛰기
Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement
필요한 것
  1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement, Scroll Wheel Encoder: 1 단계, 이미지 1개 중 1개
    • Peel back the two teflon pads from the top corners and the one larger one from the bottom with the help of a spudger.
    • You will find four 7 mm screws under the teflon pads.
  2. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 3 단계, 이미지 2개 중 1개 Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 3 단계, 이미지 2개 중 2개
    • Gently remove the top plastic shell from the mouse.
    • Be careful when lifting the shell up to avoid damage to the cable connected to the board and shell.
    • The top shell is separate from the sides of the mouse.
    • Unplug the cable coming from the top shell that connects to the board.
  4. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull the two plastic sides off the mouse.
    • Pry the sides off gently so you don't crack any of the plastic tabs that hold them in place.
  5. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 5 mm screw holding the scroll wheel in place.
    • This screw is different than the ones at the bottom of the mouse so keep it separate.
  6. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 7 단계, 이미지 1개 중 1개
    • Gently slide the lighting chip up and out of the scroll wheel.
  8. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger to gently pry the scroll wheel assembly out from the plastic housing.
  9. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the scroll wheel from the holder by pushing it up from underneath.
  10. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the old encoder chip and replace with the new one.
    • Make sure that the silver part of the encoder faces out and that the small square points down when reinstalling.
결론
작성자
1다른 기여자 명과 함께
Tony Di Folca
회원 가입일: 05/13/19
231 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 85
전체 시간: 2,685
