주요 콘텐츠로 건너뛰기
Razer Naga Epic Chroma Top Casing Replacement
필요한 것
  1. Razer Naga Epic Chroma Top Casing Replacement, Razer Naga Epic Chroma Disassembly: 1 단계, 이미지 1/1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Top Casing Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Top Casing Replacement: 3 단계, 이미지 1/1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Top Casing Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Top Casing Replacement, Top Plastic Casing: 5 단계, 이미지 1/1
    • Plug the new top casing's cable back into the socket on the right side of the circuit board near the middle.
    • Reassemble the device.
    • Test device to make sure the connections function correctly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Morgan
회원 가입일: 01/19/17
886 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 1,808
