주요 콘텐츠로 건너뛰기
Razer Naga Epic Top Panel Disassembly
필요한 것
  1. Razer Naga Epic Top Panel Disassembly, Identify attachment points: 1 단계, 이미지 1/2 Razer Naga Epic Top Panel Disassembly, Identify attachment points: 1 단계, 이미지 2/2
    • The PCB is held to the top panel by...
    • 2 x 6mm Phillips #0 screws towards the front
    • 2 grooves on the top panel holding it in towards the rear
  2. Razer Naga Epic Top Panel Disassembly, Unscrew the PCB: 2 단계, 이미지 1/1
    • Unscrew the 2 screws holding the PCB into the top panel.
  3. Razer Naga Epic Top Panel Disassembly, Slide PCB away from the top panel: 3 단계, 이미지 1/3 Razer Naga Epic Top Panel Disassembly, Slide PCB away from the top panel: 3 단계, 이미지 2/3 Razer Naga Epic Top Panel Disassembly, Slide PCB away from the top panel: 3 단계, 이미지 3/3
    • Carefully slide the PCB horizontally away from the grooves on the rear end of the top panel.
결론
Caius Nocturne
회원 가입일: 07/12/21
2,076 평판
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 52
