이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will help you replace the motherboard which allows your mouse to function . Be sure to keep track of the 5mm screws and the 7mm screws.
필요한 것
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the circuit board to the main frame.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Surprised this is rated Difficult. :f
Do you know where I can find the motherboard for the mouse?
Where can I get a replacement motherboard?
I followed these steps for the razer naga hex and it's the same. Just a tip for people that want to take off the teflon tapes, you don't need to take off the big one to the side, the only 4 screws holding the case to the top part of the mouse are under the 4 small teflon tapes in each corner. Good luck!
