주요 콘텐츠로 건너뛰기
Razer Naga Expert MMO Scroll Wheel Replacement
필요한 것
  1. Razer Naga Expert MMO Scroll Wheel Replacement, Top Plastic Shell: 1 단계, 이미지 1/1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Scroll Wheel Replacement: 2 단계, 이미지 1/1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Scroll Wheel Replacement: 3 단계, 이미지 1/1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Scroll Wheel Replacement: 4 단계, 이미지 1/1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Scroll Wheel Replacement, Scroll Wheel: 5 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
  6. Razer Naga Expert MMO Scroll Wheel Replacement: 6 단계, 이미지 1/1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga Expert MMO Scroll Wheel Replacement: 7 단계, 이미지 1/1
    • Slide the chip out of the scroll wheel.
  8. Razer Naga Expert MMO Scroll Wheel Replacement: 8 단계, 이미지 1/2 Razer Naga Expert MMO Scroll Wheel Replacement: 8 단계, 이미지 2/2
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  9. Razer Naga Expert MMO Scroll Wheel Replacement: 9 단계, 이미지 1/1
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacqueline Scalzo
회원 가입일: 01/29/18
253 평판
안내서 2개 작성하였습니다
University of Alabama, Team S1-G2, Bedsole Spring 2018 University of Alabama, Team S1-G2, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 34
전체 시간: 4,488
