주요 콘텐츠로 건너뛰기
Razer Naga Expert MMO Side Button Connection Strip Replacement
필요한 것
  1. Razer Naga Expert MMO Side Button Connection Strip Replacement, Top Plastic Shell: 1 단계, 이미지 1/1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Side Button Connection Strip Replacement: 2 단계, 이미지 1/1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Side Button Connection Strip Replacement: 3 단계, 이미지 1/1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Side Button Connection Strip Replacement: 4 단계, 이미지 1/1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Side Button Connection Strip Replacement, Side Button Connection Strip: 5 단계, 이미지 1/1
    • Flip back the black plastic that holds the white connection strip in place on the side panel and the main panel.
  6. Razer Naga Expert MMO Side Button Connection Strip Replacement: 6 단계, 이미지 1/1
    • Gently remove the white connection strip at each end.
  7. Razer Naga Expert MMO Side Button Connection Strip Replacement: 7 단계, 이미지 1/1
    • Insert the blue striped ends into the white connection port on the mainframe as well as the frame with the buttons.
결론
Laura Rubisch
회원 가입일: 01/29/18
115 평판
안내서 1개 작성함
University of Alabama, Team S1-G2, Bedsole Spring 2018 University of Alabama, Team S1-G2, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
What is the code for the connection strip and how many pins does it have?
Thank you for the guide.
Tsuki Yomi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 20
전체 시간: 2,327
