주요 콘텐츠로 건너뛰기
Razer Naga Expert MMO Top Plastic Shell Replacement
필요한 것
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: 1 단계, 이미지 1/1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: 2 단계, 이미지 1/1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: 3 단계, 이미지 1/1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: 4 단계, 이미지 1/1
    • Lightly pull the two plastic sides of the mouse to remove them.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gianni Conti
회원 가입일: 01/29/18
461 평판
안내서 2개 작성하였습니다
University of Alabama, Team S1-G2, Bedsole Spring 2018 University of Alabama, Team S1-G2, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 2개
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - 답글
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 27
전체 시간: 1,835
