주요 콘텐츠로 건너뛰기
Razer Naga Trinity LED Light Ribbon Cable Replacement
필요한 것
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: 1 단계, 이미지 1/2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: 1 단계, 이미지 2/2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: 2 단계, 이미지 1/2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 2 단계, 이미지 2/2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: 3 단계, 이미지 1/1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: 4 단계, 이미지 1/2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 4 단계, 이미지 2/2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: 5 단계, 이미지 1/1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: 6 단계, 이미지 1/1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: 7 단계, 이미지 1/2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 7 단계, 이미지 2/2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: 8 단계, 이미지 1/2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: 8 단계, 이미지 2/2
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
결론
Alexandros Andreou
회원 가입일: 09/16/19
700 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 36
전체 시간: 1,572
