주요 콘텐츠로 건너뛰기
Razer Naga Trinity Scroll Wheel Housing Replacement
필요한 것
  1. Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: 1 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: 1 단계, 이미지 2/2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity Scroll Wheel Housing Replacement: 2 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement: 2 단계, 이미지 2/2
    • Remove the mouse's feet using the opening pick.
    Be aware that it’s possible to peel the feet from the glue layer.
    SteepPoppy0 - 답글
  3. Razer Naga Trinity Scroll Wheel Housing Replacement: 3 단계, 이미지 1/1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity Scroll Wheel Housing Replacement: 4 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement: 4 단계, 이미지 2/2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity Scroll Wheel Housing Replacement: 5 단계, 이미지 1/1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity Scroll Wheel Housing Replacement: 6 단계, 이미지 1/1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity Scroll Wheel Housing Replacement: 7 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement: 7 단계, 이미지 2/2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: 8 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: 8 단계, 이미지 2/2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity Scroll Wheel Housing Replacement: 9 단계, 이미지 1/1
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity Scroll Wheel Housing Replacement: 10 단계, 이미지 1/1
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity Scroll Wheel Housing Replacement: 11 단계, 이미지 1/2 Razer Naga Trinity Scroll Wheel Housing Replacement: 11 단계, 이미지 2/2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity Scroll Wheel Housing Replacement: 12 단계, 이미지 1/3 Razer Naga Trinity Scroll Wheel Housing Replacement: 12 단계, 이미지 2/3 Razer Naga Trinity Scroll Wheel Housing Replacement: 12 단계, 이미지 3/3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
    You don't have to remove that part, if you're careful you can leave the mouse wheel attatched to the mainboard because it's pretty fiddly to get the feather inside again.
    Andreas - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
81,824 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
can you give a link for a replacement scroll wheel if possible?
joe - 답글
nice guide but i sadly didn’t found any housing wheel replacement part ><
Zzz Zzz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 102
전체 시간: 4,255
