이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide is for replacing the scroll wheel on the Razer Naga Trinity gaming mouse (RZ01-0241). If the mouse is used for an extended period of time, the scroll wheel can become dirty or start to wear out, negatively effecting the user’s experience. A common problem that may occur is the rubber on the scroll wheel deteriorating from the oils on the hand and friction. Another problem is dirt collecting between the optical encoder and the scroll wheel (Optical Encoder Replacement). This will hinder the response time and accuracy of the user’s input. There are no special skills required to perform this replacement.
필요한 것
Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
Then pull the LED controller board upwards and out.
다른 2명이 해당 안내서를 완성하였습니다.
