부품
지정된 부품이 없습니다.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Separate the top mouse housing from the bottom mouse housing using the opening pick.
Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
Remove the top housing LED 3-Pin connector that is near the main board.
Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
Then pull the LED controller board upwards and out.
Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
다른 2명이 해당 안내서를 완성하였습니다.
