주요 콘텐츠로 건너뛰기
Razer OSVR HDK 1.4 (and others) Face Plate Replacement
필요한 것
  1. Razer OSVR HDK 1.4 (and others) Face Plate Replacement, Opening the HDK: 1 단계, 이미지 1/2 Razer OSVR HDK 1.4 (and others) Face Plate Replacement, Opening the HDK: 1 단계, 이미지 2/2
    • Lay HDK headset face down. Remove the two Phillips #00 screws from the bottom.
    • Turn upright and gently pull face plate forward. (Pulling forward and to the left will help avoid strain on the tracking ribbon cables.) There's two grooves to help with this on the top part. It's a magnetic plate, does not take much effort.
    • The "infamous" face plate connector is on the inside between the board and face plate. I marked the approximate location in red here, be careful when opening not to pull hard as people have stated that it breaks easily rendering your headset positional tracking useless if the connector tears off. (If it just disconnects, see below to reconnect.)
  2. Razer OSVR HDK 1.4 (and others) Face Plate Replacement, Exchanging the Face Plate: 2 단계, 이미지 1/1
    • The connector is held together by tape. Gently peel the tape away. The male and female parts are just barely interlocking.
    • There's suppose to be a very slight click when attaching the new connector together - be sure to assemble the two halves flat. Once that is done, tape it back together.
결론
Tom
회원 가입일: 07/05/16
201 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 439
