주요 콘텐츠로 건너뛰기
Razer Ouroboros Battery Replacement
필요한 것
  1. Razer Ouroboros Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
  2. Razer Ouroboros Battery Replacement: 2 단계, 이미지 1개 중 1개
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: 3 단계, 이미지 1개 중 1개
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brandon Jones
회원 가입일: 07/19/16
308 평판
안내서 1개를 작성함
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016 회원
UM-KIM-SU16S1G2
3 회원들
안내서 4개를 작성함
8가이드 댓글
is the battery a standard AA battery size or did they use a different size?
adiforipod - 답글
Standard AA size mate
Minty Fox - 답글
… what happens if I don't use a rechargeable battery?
Russell Phillips - 답글
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 80
전체 시간: 20,714
