주요 콘텐츠로 건너뛰기
Razer Ouroboros Lock Switch Replacement
필요한 것
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: 1 단계, 이미지 1/2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: 1 단계, 이미지 2/2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: 2 단계, 이미지 1/2 Razer Ouroboros Lock Switch Replacement: 2 단계, 이미지 2/2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: 3 단계, 이미지 1/2 Razer Ouroboros Lock Switch Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Preston Darling
회원 가입일: 07/26/16
372 평판
안내서 2개 작성하였습니다
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016 회원
UM-KIM-SU16S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 25
전체 시간: 3,229
