주요 콘텐츠로 건너뛰기
Razer Ouroboros Scroll Wheel Replacement
필요한 것
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Razer Ouroboros Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: 3 단계, 이미지 3개 중 1개 Razer Ouroboros Scroll Wheel Replacement: 3 단계, 이미지 3개 중 2개 Razer Ouroboros Scroll Wheel Replacement: 3 단계, 이미지 3개 중 3개
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: 4 단계, 이미지 3개 중 1개 Razer Ouroboros Scroll Wheel Replacement: 4 단계, 이미지 3개 중 2개 Razer Ouroboros Scroll Wheel Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Preston Darling
회원 가입일: 07/26/16
372 평판
안내서 2개를 작성함
University of Memphis, Team 1-2, Kim SU 2016 University of Memphis, Team 1-2, Kim SU 2016 회원
UM-KIM-SU16S1G2
3 회원들
안내서 4개를 작성함
1가이드 댓글
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 4,504
