주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Phone Battery Replacement
필요한 것
  1. Razer Phone Battery Replacement, Display Assembly: 1 단계, 이미지 3개 중 1개 Razer Phone Battery Replacement, Display Assembly: 1 단계, 이미지 3개 중 2개 Razer Phone Battery Replacement, Display Assembly: 1 단계, 이미지 3개 중 3개
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Battery Replacement: 2 단계, 이미지 2개 중 1개 Razer Phone Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Battery Replacement: 3 단계, 이미지 3개 중 1개 Razer Phone Battery Replacement: 3 단계, 이미지 3개 중 2개 Razer Phone Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Battery Replacement: 4 단계, 이미지 2개 중 1개 Razer Phone Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Battery Replacement: 5 단계, 이미지 3개 중 1개 Razer Phone Battery Replacement: 5 단계, 이미지 3개 중 2개 Razer Phone Battery Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Battery Replacement: 6 단계, 이미지 2개 중 1개 Razer Phone Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
  7. Razer Phone Battery Replacement, Battery: 7 단계, 이미지 3개 중 1개 Razer Phone Battery Replacement, Battery: 7 단계, 이미지 3개 중 2개 Razer Phone Battery Replacement, Battery: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Battery Replacement: 8 단계, 이미지 2개 중 1개 Razer Phone Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
  9. Razer Phone Battery Replacement: 9 단계, 이미지 3개 중 1개 Razer Phone Battery Replacement: 9 단계, 이미지 3개 중 2개 Razer Phone Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Peel off and pull out the elastic tabs at the bottom of the battery.
  10. Razer Phone Battery Replacement: 10 단계, 이미지 2개 중 1개 Razer Phone Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully use the Jimmy to wedge the battery out of the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bryan
회원 가입일: 01/24/19
777 평판
안내서 2개를 작성함
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 회원
CPSU-WHITE-W19S19G6
4 회원들
안내서 10개를 작성함
5가이드 댓글
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - 답글 공유
Where can I buy a battery and power button replacement for this phone
Kelly Sales - 답글 공유
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - 답글 공유
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - 답글 공유
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto - 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 39
지난 30일: 125
전체 시간: 19,493
