소개
Is your Razer Phone having problems with the battery and you need to replace it? Follow this easy guide to replacing the battery on your phone. You'll need the #000 Phillips screw driver, the Torx head T5, the tweezers, the metal spudger and the jimmy.
필요한 것
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
Peel back the metallic shielding over the connector using tweezers.
Remove the metal bracket connector.
Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
I would highly recommend avoid using metal tweezers for this step.
Otherwise, be EXTREMELY careful with them when near the contacts around the ribbon cable.
With the battery still plugged in, trying to unplug the ribbon connector of the screen with a metal tool will cause shorts between the tiny contacts.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Carefully use the Jimmy to wedge the battery out of the phone.
Thank you very much.
I used this guide to replace my battery for my Razer 2 phone and the front speaker grills have no screws at all. Had to access the battery from behind the phone. So apparently I have a different version of Razer 2 phone. So followed another guide and replaced the battery. Unfortunately, I had to deal with the speaker grills.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Where can I buy a battery and power button replacement for this phone
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Double sided tape can be used to adhere the grills in place.
Lucano - 답글
How to make the Another adhesive??? Plz rply
My razed Phone Speaker grills can't put again Perfectly
Ferdi Pongbubun - 답글
Where can i find a Charging Connector for Razer Phone 2 to buy….becouse the only place i când find IT is in India and they only delyver to
curteanuice13 - 답글
