주요 콘텐츠로 건너뛰기
Razer Phone Display Assembly Replacement
필요한 것
  1. Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/3 Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/3 Razer Phone Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Display Assembly Replacement: 2 단계, 이미지 1/2 Razer Phone Display Assembly Replacement: 2 단계, 이미지 2/2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Display Assembly Replacement: 3 단계, 이미지 1/3 Razer Phone Display Assembly Replacement: 3 단계, 이미지 2/3 Razer Phone Display Assembly Replacement: 3 단계, 이미지 3/3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Display Assembly Replacement: 4 단계, 이미지 1/2 Razer Phone Display Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Display Assembly Replacement: 5 단계, 이미지 1/3 Razer Phone Display Assembly Replacement: 5 단계, 이미지 2/3 Razer Phone Display Assembly Replacement: 5 단계, 이미지 3/3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Display Assembly Replacement: 6 단계, 이미지 1/2 Razer Phone Display Assembly Replacement: 6 단계, 이미지 2/2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Sebastian Barragan
회원 가입일: 01/24/19
435 평판
안내서 1개 작성함
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 회원
CPSU-WHITE-W19S19G6
5 회원들
안내서 12개 작성하였습니다
댓글 14개
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - 답글
Double sided tape.
Lucano -
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - 답글
Search on eBay. Phones are often parted out there.
Lucano -
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Lucano -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 63
전체 시간: 14,985
