주요 콘텐츠로 건너뛰기
Razer Phone Earpiece Speaker Replacement
필요한 것
  1. Razer Phone Earpiece Speaker Replacement, Display Assembly: 1 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement, Display Assembly: 1 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    Double sided tape can be used to adhere the grills in place.
    Lucano - 답글
    How to make the Another adhesive??? Plz rply
    My razed Phone Speaker grills can't put again Perfectly
    Ferdi Pongbubun - 답글
    Where can i find a Charging Connector for Razer Phone 2 to buy….becouse the only place i când find IT is in India and they only delyver to
    curteanuice13 - 답글
  2. Razer Phone Earpiece Speaker Replacement: 2 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 2 단계, 이미지 2/2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Earpiece Speaker Replacement: 3 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 3 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 3 단계, 이미지 3/3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Earpiece Speaker Replacement: 4 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Earpiece Speaker Replacement: 5 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 5 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 5 단계, 이미지 3/3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    Hi you got any screen for sale thanks
    anwarhussain21786 - 답글
  6. Razer Phone Earpiece Speaker Replacement: 6 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 6 단계, 이미지 2/2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    I would highly recommend avoid using metal tweezers for this step.
    Otherwise, be EXTREMELY careful with them when near the contacts around the ribbon cable.
    With the battery still plugged in, trying to unplug the ribbon connector of the screen with a metal tool will cause shorts between the tiny contacts.
    John Li - 답글
  7. Razer Phone Earpiece Speaker Replacement, Battery: 7 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement, Battery: 7 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement, Battery: 7 단계, 이미지 3/3
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Earpiece Speaker Replacement: 8 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 8 단계, 이미지 2/2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    Careful.
    There's actually 2 screws you need to remove with this step before you can remove the bracket..
    John Li - 답글
  9. Razer Phone Earpiece Speaker Replacement: 9 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 9 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 9 단계, 이미지 3/3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    It isn’t necessary to remove the battery.
    Lucano - 답글
  10. Razer Phone Earpiece Speaker Replacement: 10 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 10 단계, 이미지 2/2
    • Carefully use the Jimmy to wedge the battery out of the phone.
    Lucano - 답글
    battery razer phone 1 and 2 is the same type?
    my phone is razer phone 1, and only see online shop selling the battery for razer phone 2
    Alpha Jon - 답글
    Where I can get the design specs for the razer phone 1 battery? I think they are not producing it anymore…
    h_yilei - 답글
    It is 376989 in size I brought a 396787 but without the BMS board specs still cannot fix it.
    And also what is the Panasonic 777156? It has 6 pins under it, it seems not like a capacitor and cannot find replacement on digi-key.
    h_yilei - 답글
    I used this guide to replace my battery for my Razer 2 phone and the front speaker grills have no screws at all. Had to access the battery from behind the phone. So apparently I have a different version of Razer 2 phone. So followed another guide and replaced the battery. Unfortunately, I had to deal with the speaker grills.
    Nick T - 답글
  11. Razer Phone Earpiece Speaker Replacement, Charging Port: 11 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement, Charging Port: 11 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
    • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
    This step isn’t necessary.
    Lucano - 답글
  12. Razer Phone Earpiece Speaker Replacement: 12 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 12 단계, 이미지 2/2
    • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
    It isn’t necessary to peel the ribbon from the casing.
    Lucano - 답글
  13. Razer Phone Earpiece Speaker Replacement: 13 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 13 단계, 이미지 2/2
    • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
    • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
    Lucano - 답글
  14. Razer Phone Earpiece Speaker Replacement: 14 단계, 이미지 1/1
    • Using the tweezers, grab the detached charging port and ribbon.
    Lucano - 답글
  15. Razer Phone Earpiece Speaker Replacement, Rear Camera: 15 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement, Rear Camera: 15 단계, 이미지 2/2
    • Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
  16. Razer Phone Earpiece Speaker Replacement: 16 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 16 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 16 단계, 이미지 3/3
    • Remove the protective peel covering the rear cameras using your hands.
  17. Razer Phone Earpiece Speaker Replacement: 17 단계, 이미지 1/1
    • Use the tweezers to remove the white tab connector.
  18. Razer Phone Earpiece Speaker Replacement: 18 단계, 이미지 1/1
    • Grab and remove the metal tab with the tweezers.
  19. Razer Phone Earpiece Speaker Replacement: 19 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 19 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 19 단계, 이미지 3/3
    • Grab the connectors with the tweezers and gently lift the connectors loose.
    It is only necessary to remove the left connector tab to reveal the screw beneath.
    Lucano - 답글
  20. Razer Phone Earpiece Speaker Replacement: 20 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 20 단계, 이미지 2/2
  21. Razer Phone Earpiece Speaker Replacement: 21 단계, 이미지 1/1
    • Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
  22. Razer Phone Earpiece Speaker Replacement: 22 단계, 이미지 1/3 Razer Phone Earpiece Speaker Replacement: 22 단계, 이미지 2/3 Razer Phone Earpiece Speaker Replacement: 22 단계, 이미지 3/3
    • Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
    Lucano - 답글
  23. Razer Phone Earpiece Speaker Replacement, Motherboard: 23 단계, 이미지 1/1
    • Grab and remove the blue connector with the tweezers.
    If you remember, this was done in step 12.
    Lucano - 답글
  24. Razer Phone Earpiece Speaker Replacement: 24 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 24 단계, 이미지 2/2
    • Remove the five 1 mm screws holding down the gold antenna line brackets to the motherboard using the Phillips #000 screwdriver.
  25. Razer Phone Earpiece Speaker Replacement: 25 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 25 단계, 이미지 2/2
    • Remove the 2.5 mm screw next to the front-facing camera with the Phillips #000 screwdriver.
  26. Razer Phone Earpiece Speaker Replacement: 26 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement: 26 단계, 이미지 2/2
    • Remove the four gold antenna line brackets with the tweezers.
  27. Razer Phone Earpiece Speaker Replacement: 27 단계, 이미지 1/1
    • Using the tweezers remove the SIM card tray from the body of the phone.
  28. Razer Phone Earpiece Speaker Replacement: 28 단계, 이미지 1/1
    • Carefully lift up the motherboard away from the device.
  29. Razer Phone Earpiece Speaker Replacement, Earpiece Speaker: 29 단계, 이미지 1/2 Razer Phone Earpiece Speaker Replacement, Earpiece Speaker: 29 단계, 이미지 2/2
    • Lift earpiece speaker up with the tweezers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Guneet Kohli
회원 가입일: 01/24/19
162 평판
안내서 1개 작성함
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 회원
CPSU-WHITE-W19S19G6
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
This job shouldn’t take more than an hour.
Lucano - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 23
전체 시간: 6,345
