이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Pry the top plastic grill off with the metal spudger and reveal the screws.
Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
Lift the display assembly away from the other half of the phone.
Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
Peel back the metallic shielding over the connector using tweezers.
Remove the metal bracket connector.
Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
Grab the bracket with the tweezers and remove it.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
Grab hold of the blue connector on the upper left side of the phone with the tweezers.
Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
Grab the connectors with the tweezers and gently lift the connectors loose.
Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
