주요 콘텐츠로 건너뛰기
Razer Tartarus V2 Keycap Stabilizers Replacement
필요한 것
  1. Razer Tartarus V2 Keycap Stabilizers Replacement, Razer Tartarus V2 Case Disassembly: 1 단계, 이미지 2개 중 1개 Razer Tartarus V2 Keycap Stabilizers Replacement, Razer Tartarus V2 Case Disassembly: 1 단계, 이미지 2개 중 2개
    • Turn the keypad upside down.
  2. Razer Tartarus V2 Keycap Stabilizers Replacement: 2 단계, 이미지 3개 중 1개 Razer Tartarus V2 Keycap Stabilizers Replacement: 2 단계, 이미지 3개 중 2개 Razer Tartarus V2 Keycap Stabilizers Replacement: 2 단계, 이미지 3개 중 3개
    • Gently peel off the rubber feet with a Jimmy.
    • Set the rubber grip pads aside so you can reapply them later.
    • Use a Phillips #0 screwdriver to remove the following screws:
    • Twelve 6.4 mm-long screws
    • Two 3.7 mm-long screws
  3. Razer Tartarus V2 Keycap Stabilizers Replacement: 3 단계, 이미지 3개 중 1개 Razer Tartarus V2 Keycap Stabilizers Replacement: 3 단계, 이미지 3개 중 2개 Razer Tartarus V2 Keycap Stabilizers Replacement: 3 단계, 이미지 3개 중 3개
    • Peel up the bottom left corner of the largest sticker.
    • Remove the 6.4 mm-long Phillips #0 screw.
  4. Razer Tartarus V2 Keycap Stabilizers Replacement: 4 단계, 이미지 3개 중 1개 Razer Tartarus V2 Keycap Stabilizers Replacement: 4 단계, 이미지 3개 중 2개 Razer Tartarus V2 Keycap Stabilizers Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully lift the joystick module up and out.
    • Separate the top and bottom casing of the keypad.
    • Use an Opening tool to pry the case open along the edges if necessary.
  5. Razer Tartarus V2 Keycap Stabilizers Replacement, Keycap Stabilizers: 5 단계, 이미지 2개 중 1개 Razer Tartarus V2 Keycap Stabilizers Replacement, Keycap Stabilizers: 5 단계, 이미지 2개 중 2개
    • Locate the two rubber stabilizers:
    • One large stabilizer is positioned under keys 1–19.
    • One small stabilizer is under key 20.
    • Carefully pull each stabilizer up by hand from its respective board (motherboard or daughterboard)
    • Avoid applying excessive force or using sharp tools to prevent scratching or damaging the boards beneath the stabilizers.
결론
작성자
3다른 기여자 명과 함께
Derrick
회원 가입일: 02/21/25
569 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 155
