주요 콘텐츠로 건너뛰기
Razer Viper Ultimate Upper Shell Replacement
필요한 것
  1. Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 1 단계, 이미지 3개 중 1개 Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 1 단계, 이미지 3개 중 2개 Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 1 단계, 이미지 3개 중 3개
    • Gently use a flathead screwdriver to lift and take off the mouse skates, exposing the screws.
  2. Razer Viper Ultimate Upper Shell Replacement: 2 단계, 이미지 3개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 2 단계, 이미지 3개 중 2개 Razer Viper Ultimate Upper Shell Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T5 hex-bit screwdriver to remove the four 2 mm screws from the bottom cover of the mouse.
  3. Razer Viper Ultimate Upper Shell Replacement: 3 단계, 이미지 3개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 3 단계, 이미지 3개 중 2개 Razer Viper Ultimate Upper Shell Replacement: 3 단계, 이미지 3개 중 3개
    • With the flathead screwdriver, carefully open the sides and back, unclipping the bottom shell from the mouse.
  4. Razer Viper Ultimate Upper Shell Replacement: 4 단계, 이미지 2개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the three-pin connector cable under the Printed Circuit Board (PCB). Take off the cable with yellow, red, and black wires to reach the four 2.5 mm screws holding the battery and switches.
  5. Razer Viper Ultimate Upper Shell Replacement: 5 단계, 이미지 2개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 5 단계, 이미지 2개 중 2개
    • Use a small Phillips-head screwdriver to remove the four 2.5 mm screws that secure the battery unit.
  6. Razer Viper Ultimate Upper Shell Replacement: 6 단계, 이미지 2개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 6 단계, 이미지 2개 중 2개
    • Move the PCB with the battery from the old shell to the new one. Align the 4 plastic guide pegs with the holes in the PCB.
  7. Razer Viper Ultimate Upper Shell Replacement: 7 단계, 이미지 1개 중 1개
    • Screw the 2.5 mm screws back into the switch pack and battery using the small Phillips-head screwdriver, following the layout of the new shell.
    • Adjust screw placement if needed.
  8. Razer Viper Ultimate Upper Shell Replacement: 8 단계, 이미지 2개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 8 단계, 이미지 2개 중 2개
    • Reconnect the three-pin connector cables from step 4.
  9. Razer Viper Ultimate Upper Shell Replacement: 9 단계, 이미지 1개 중 1개
    • Attach the bottom half of the mouse to the shell, ensuring everything is in its original place.
  10. Razer Viper Ultimate Upper Shell Replacement: 10 단계, 이미지 3개 중 1개 Razer Viper Ultimate Upper Shell Replacement: 10 단계, 이미지 3개 중 2개 Razer Viper Ultimate Upper Shell Replacement: 10 단계, 이미지 3개 중 3개
    • Screw in the four 2 mm hex screws on the bottom cover of the mouse (refer to step 2).
    • Finally, put the skates back on.
결론
Your Razer Viper Ultimate Mouse is now successfully reassembled in its new shell! Ensure all components are securely in place before use.
작성자
4다른 기여자 명과 함께
Nora Kanaan
회원 가입일: 02/08/24
185 평판
안내서 1개를 작성함
1가이드 댓글
I think the model you have is different a T5 is to small for the screws in mine
Kodi Davis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 37
지난 30일: 182
전체 시간: 2,901
