주요 콘텐츠로 건너뛰기
Razor A Handle Grips Replacement
필요한 것
  1. Razor A Handle Grips Replacement, Handle Grips: 1 단계, 이미지 1/2 Razor A Handle Grips Replacement, Handle Grips: 1 단계, 이미지 2/2
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: 2 단계, 이미지 1/2 Razor A Handle Grips Replacement: 2 단계, 이미지 2/2
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: 3 단계, 이미지 1/2 Razor A Handle Grips Replacement: 3 단계, 이미지 2/2
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jordyn
회원 가입일: 10/09/12
544 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G13
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 4,808
