주요 콘텐츠로 건너뛰기
Razor AW Kick Wheel Bar Replacement
필요한 것
  1. Razor AW Kick Wheel Bar Replacement, Wheel Bar: 1 단계, 이미지 1/3 Razor AW Kick Wheel Bar Replacement, Wheel Bar: 1 단계, 이미지 2/3 Razor AW Kick Wheel Bar Replacement, Wheel Bar: 1 단계, 이미지 3/3
    • Place the scooter on its side and on the ground.
    • Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
    • Remove the screw using the 5 mm Hex Security key.
    • Remove the screw from the scooter frame.
  2. Razor AW Kick Wheel Bar Replacement: 2 단계, 이미지 1/3 Razor AW Kick Wheel Bar Replacement: 2 단계, 이미지 2/3 Razor AW Kick Wheel Bar Replacement: 2 단계, 이미지 3/3
    • Remove the wheel from the scooter slowly.
    • Remove the black wheel holders from the scooter frame.
  3. Razor AW Kick Wheel Bar Replacement: 3 단계, 이미지 1/2 Razor AW Kick Wheel Bar Replacement: 3 단계, 이미지 2/2
    • Remove the wheel bar from the scooter frame.
결론
To reassemble your device, follow these instructions in revise order.
Alexander Vazquez
회원 가입일: 10/26/22
97 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-5, Briggs Fall 2022 CSU Los Angeles, Team 1-5, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S1G5
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 204
