주요 콘텐츠로 건너뛰기
RazorX DLX Electric Skateboard Power Button Replacement
필요한 것
  1. RazorX DLX Electric Skateboard Power Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 RazorX DLX Electric Skateboard Power Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Power Button Replacement, Control Module: 3 단계, 이미지 3개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement, Control Module: 3 단계, 이미지 3개 중 2개 RazorX DLX Electric Skateboard Power Button Replacement, Control Module: 3 단계, 이미지 3개 중 3개
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Power Button Replacement: 4 단계, 이미지 3개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement: 4 단계, 이미지 3개 중 2개 RazorX DLX Electric Skateboard Power Button Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Power Button Replacement: 6 단계, 이미지 3개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement: 6 단계, 이미지 3개 중 2개 RazorX DLX Electric Skateboard Power Button Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Power Button Replacement: 7 단계, 이미지 3개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement: 7 단계, 이미지 3개 중 2개 RazorX DLX Electric Skateboard Power Button Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Power Button Replacement: 8 단계, 이미지 2개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Power Button Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the Control Module by lifting it out of the plastic housing.
  10. RazorX DLX Electric Skateboard Power Button Replacement, Power Button: 10 단계, 이미지 2개 중 1개 RazorX DLX Electric Skateboard Power Button Replacement, Power Button: 10 단계, 이미지 2개 중 2개
    • Disconnect the power button from the control module.
    • Pinch the two plastic tabs to remove the power button from the plastic body.
결론
작성자
3다른 기여자 명과 함께
Emmett Normand
회원 가입일: 10/24/24
974 평판
안내서 8개를 작성함
Cuesta, Team 20-4, Krynen Fall 2024 Cuesta, Team 20-4, Krynen Fall 2024 회원
CUESTA-KRYNEN-F24S20G4
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 105
